Sold Arc,Memphis,Treo,Planet Audio,Stinger,etc
eatank
SHDA4 $80.00
Four position, MIDI fuse distribution block with Amperage and Voltage display. Accepts two 1/0 or 4ga inputs or a combination of one each and provides four 4ga or 8ga outputs. Versatile MIDI fusing provides fuse range of 30 to 150 amps per circuit.
SHDA2PG $60.00
Two position, MIDI fuse distribution block with Amperage and Voltage display. Accepts 1/0 or 4ga input and provides two 4ga or 8ga outputs. Versatile MIDI fusing provides fuse range of 30 to 150 amps per circuit.
SWKH4- $ 47.00
Power Kit for Amplifiers up to 1400 Watts
18 feet of 4 ga. HPM Blue Power Wire
3 feet of 4 ga. HPM Clear Ground Wire
1- Platinum Plated ANL Fuse Holder with 150 Amp ANL fuse
17 feet of 18 ga. Amplifier Remote Turn-on Wire
1- Platinum Plated Super Surface Contact Grounding Terminal
10 - 7 inch wire ties
Full Assortment of Platinum Plated Terminals and Hardware
Protective, Snap-in Wire Grommet
SWK4D- $ 55.00
Multi-Amp Power Kit for Amplifiers totaling up to 1400 Watts
18 feet of 4 ga. Custom PRO Red Power Wire
10 feet of 8 ga. Custom PRO Red Power Wire
10 feet of 8 ga. Custom PRO Black Ground Wire
1- 24kt Gold Plated ANL Fuse Holder with 150 Amp ANL fuse
1- 24kt Gold Plated 4 to 8 ga. Power Distribution Block
10- 7 inch wire ties
Full Assortment of 24kt Gold Plated Terminals and Hardware
SWKH0- $85.00
Power Kit for Amplifiers up to 3400 Watts
18 feet of 1/0 ga. HPM Blue Power Wire
3 feet of 1/0 ga. HPM Clear Ground Wire
1- Platinum Plated PRO-style ANL Fuse Holder with 250 Amp ANL fuse
1- Platinum Plated Machined PRO Ring Terminal with Cover
SWK0- $75.00
18 feet of 1/0 ga. Custom PRO Red Power Wire
3 feet of 1/0 ga. Custom PRO Black Ground Wire
1- 24kt Gold Plated PRO-style ANL Fuse Holder with 250 Amp ANL fuse
1- 24kt Gold Plated Machined PRO Ring Terminal with Cover
1- 24kt Gold Plated Super Surface Contact Grounding Terminal
NITROUS STYLE CAP KIT $ 105.00
The SCSK1 kit includes our exclusive SCS 1 farad capacitor-designed to look like a Nitrous Bottle and “boost ”the system ’s power in the same way nitrous would “boost ”horsepower of an engine.To complete the package,all the necessary components to install the capacitor are included such as;mount- ing brackets,braided hose style wire, hardware,and a distribution block that provides easy installation and can be tucked out of sight.The capacitor not only improves system performance it also adds system status with an integrated digital 4-digit LED voltage gauge. 3 ”DIA 103/4 ” Tall Brackets--51/4 ”wide
Planet Audio Big Bang Amp 75.4
This amp is Brand New In Box $ 225.00
Planet Audio Big Bang Amp BB 1250.1
This amp is Brand New In Box $ 300.00
Treo SSX 1500.1 amp BNIB $ 750.00
Memphis EQP4 crossover BNIB 100.00
Memphis EQ50 crossover BNIB 55.00 missing a bracket
Memphis M3104 Subwoofer(2 of them) BNIB $350.00 for both
Blackmore 7" Screen BNIB 100.00
Memphis 12" Mojo Subwoofer BNIB $325.00
If you have any questions for pricing or need pics to see them. please ask?
Adding the DEH-P77DH Pioneer unit back into the list. 190.00 plus shipping.
I also have 1 Arc XXK1500 that was used in my demoboard for a short time in perfect condition with only mounting scratches in the legs. 300.00 plus shipping.
Eclipse da DA7232 2 CHANNEL CLASS D 4000w SUB AMP BNIB 750.00 plus shipping.
I will also be adding some more Stinger Caps that I have and maybe a few more Arc subs.
Also adding the following for 150.00 BNIB
Sound Quest By Stinger SQLKM Color Changing LED Under Car Kit
Kit features include; 140 hyper bright LED’s, virtually indestructible lexan tubes, quick and easy connection distribution block, light dispersion for neon style glow, digital control module. Each package includes two 48” LED light bars, two 36” LED light bars, all mounting hardware and a digital control module.
The digital control module comes with 9 different modes; on-full strength, series, strobe, reverse series, in / out, out / in, chase, random and music mode. The unique music mode flashes the LED’s to the beat of the vehicle’s sound system.
This is a multi-color kit.
Adding:
SoundQuest RCA 12ft Comp Twisted (2) $7.50 a piece
SoundQuest RCA 17ft Comp Twsted (2) $ 7.50 a piece
Soundquest RCA 20ft Comp Twsted (4) $ 8.50 a piece, shipping is not included with these RCA items.
No troll here. I sent the pics dconder you requested. The reason there are sales pending because I have these on other forums.
http://forum.sounddomain.com/ubb/ultimatebb.php?ubb=get_topic;f=10;t=085712
http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=20;t=012137
and a few other boards. I just thought I would try another board. I used to own a shop and it went under. I kept these products for myself, but kept to much stuff. I have a ton more stuff and am just letting go of duplicates. Please if you have any questions or want pics, please ask? dlandeis@hotmail.com
No I am not a dealer. This is stuff I have left over from when I owned a shop in 2004. After this stuff is gone, I will not sell anything ever again.
Shinobi, I will pull the sub out of the closet and take pics and email them to you. I am letting it go for 325.00 shipped.
No need to get defensive. I am just doing my job //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can sell all you want on here. As long as you arent breaking any of the rules.
Free Bump.
eatank
eatank
shingle springs,ca
eatank
