Operating voltage: 11 to 16 volts
Chassis Fuse: 2A mini-ATC
Audio Signal:
Minimum input voltage: 500 mV RMS
Maximum input voltage: 9 Volts RMS
Maximum output voltage: 9 Volts RMS
SNR (signal to noise), A Weighted: Re: 9 Volts / 120 dB
Channel Separation: Re: 9 Volts / 80 dB
Equalization: 25, 31.5, 40, 50, 63, 80, 100, 126, 156,
30 bands 200, 250, 320, 400, 500, 635, 800,
1/3 octave centering 1.27K, 1.6K, 2K, 2.5K, 3.2K, 4K, 5K,
+/- 12 dB per band 6.4K, 8K, 10K, 12.8K, 16K, 20K
measured in Hz.
Dimensions:
Width: 10.25 in / 26.04 cm
Depth: 7.50 in / 19.05 cm
Height: 1.125 in / 2.86 cm
