kicker 1500.1
zack1442
u mad
i want to get this amp because i get a pretty decent price on this..and was thinking about getting the l7 15..but im not sure if this amp will run good at 1 ohm..so im not sure on if i should get the dual 2 or 4...has anyone had experience with this set up or does anyone know the best way i should go about doing this?
I don't know if that amp is 1Ohm stable. The specs don't list a rating at 1Ohm so, I'd assume it won't do too well at that Ohm load. The 15" L7 is rated at 1000rms. With the ZX750.1, you'd be underpowering it a little. Not that it would be bad but I'd want to put the most at it I could.
If you end up with the ZX750.1, I'd get an L7 with dual 4Ohm voice coils and run it in parallel. If you ever decided to get another one, you'd need a 1Ohm stable amp. Just something to keep in mind.
zack1442
u mad
zack1442
lindenhurst,il
DBz Hertz
