Kicker 10" sub i need an amp
If it's one 4-ohm single voice coil sub, I'd get a 2-channel amp and bridge it to get max power out of the amp for your dollar.
Look at Panasonic... they have one that will do about 750 watts RMS at a little over $100.
The Solobaric L7 is not an SVC driver //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
montathon~
Is your L7 a Dual 2 Ohm or Dual 4 Ohm version?
If the former you're going to want an amp that makes the power you need at either 4 Ohms or 1 Ohm.
If the latter you'll want an amp that will give you the power you need when shown a 2 Ohm load.
All you've given us as far as $$$ is concerned is "not too much."
How about a ballpark range as far as an actual budget goes? That, along with the voice coil configuration of your specific sub will go a long way towards us making an educated amp recommendation.
montathon
montathon
PA
Prowler573
