Kicker 06ZX1000.1 Mono amp
serjr711.
Item(s) for Sale: ^^^
RMS Power: 500W x 1 @ 4 ohms
RMS Power: 1,000W x 1 @ 2 ohms
THD at 4-Ohm RMS Power:
Speaker Level Inputs
Preamp Outputs
LP Built-In Crossovers
Bass Boost: 0 - 18 dB
Frequency Response: 25-200Hz
Signal to Noise Ratio: 60 dB
Advanced chassis with extruded aluminum heatsink
Efficient class D circuitry
Top-mounted controls
KickBass 0-18 dB variable bass boost at 40 Hz
Variable 50-200 Hz low-pass crossover with 24 dB/octave slope
Defeatable 25 Hz subsonic filter
High level or low level inputs (125mV-10V)
PreAmp Signal Transfer (PAST) RCA outputs
Delayed turn-off logic circuit
Soft start turn-on circuit for reduced startup load
Short circuit, Over-voltage, Reverse polarity, Thermal overload (SORT) protection
Included remote KickBass control
Fully CEA-2006 compliant specifications for real-world power
functionality: 10/10 looks:9/10 few scratches,dusty
Price: 190.00 shipped FIRM
Shipping and Miscellaneous Item Information: usps
IMAG0701 by cartman38, on Flickr
IMAG0699 by cartman38, on Flickr
IMAG0697 by cartman38, on Flickr
For some reason I can't edit original post. Correct specs on amp:
Class D mono subwoofer amplifier: Provides massive power to your subwoofer without drawing lots of power from your system.
RMS Power Output
4 ohms: 500 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
Protection circuitry: Protects against short circuits, overloads, heat and reverse polarity.
Expansion options: Speaker-level and RCA inputs make it easy to add on to your system.
Variable crossover: LP(50 - 200 Hz)
Signal-to-Noise Ratio: 95 dB
Speaker and preamp level inputs
Remote level control included
serjr711.
serjr711.
Antioch,Ca
serjr711.
