While you might think you're funny, you're not. Kerfing is a very standard woodworking procedure for bending wood. It has nothing to do with audio in the slightest.Aside for the aesethetic appeal of the kerfed wood, the curavture provides a more round enviroment allowing the bass to speed up really fast as it exits the box thus providing more spl and more sq at the same time.
Not many people can handle it
It's called the kerf effect
While you might think your being smart, you're not. You see this topic has been covered countless time so all your really doing is regurgitating the same information that's been stated in the aforemention similiar threadsWhile you might think you're funny, you're not. Kerfing is a very standard woodworking procedure for bending wood. It has nothing to do with audio in the slightest.
I'm glad that having a low intellect is amusing to you because it definitely was not funny in the slightest.While you might think your being smart, you're not. You see this topic has been covered countless time so all your really doing is regurgitating the same information that's been stated in the aforemention similiar threads
but it sounded legit
FYI I laughed for hours on end as I read over my previous post
No sir, mobes is correct. What's happening is that the air in the port is getting compressed to the point that once it reaches an area lower pressure aka the outside, it sprays out everywhere. Kinda like holding the end of a hose slightly closed. I have a 3" aero in my car and it's straight as can be and I still get port noise (8W7) when the sub's really cranking. It's just due to more air than can fit is trying to get down the port at the same time. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifim going to have to disagree with you there just because from what ive seen, port noise generally is the sound of the wind whipping around the hard corners at the end of the port, not a true characteristic of the port itself.
also you can get away with so much less port area using an aeroport, but the shape of the port itself really has little to do with that.
imo of course.
thank youNo sir, mobes is correct. What's happening is that the air in the port is getting compressed to the point that once it reaches an area lower pressure aka the outside, it sprays out everywhere. Kinda like holding the end of a hose slightly closed. I have a 3" aero in my car and it's straight as can be and I still get port noise (8W7) when the sub's really cranking. It's just due to more air than can fit is trying to get down the port at the same time. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
