kenwood amps?
Kenwood doesnt make the greatest amps...but they arent asbad as pyle either...
I have had mine for 2 years, and who knows how long it was in the car prior to that...and i have never had any problems at all out of mine...
they dont do rated power though...
I,ve had a chance to play with the new Kenwood amps.
The 9152 will do its rated power of 500 @ 4ohms and 900 @ 2 or 1ohms(regulated)
It also has CEA certification backing that up.
I think its a great amp for the money and would recommend it.
As for chris'es Kenwood KAC-929 here is a reveiw by Brian Smith of Car Sound & performance
The KAC-929 is a two-channel amp with power ratings of 150 watts x 2 or 460 watts x 1 into 4 ohms and 230 watts x2 into 2 ohms. Features include a variable low pass filter, switchable bass boost, an expander, speaker level inputs, and fan-forced cooling.
Performance
The KAC-929 performed quite well on the test bench. While it didn’t post any surprisingly large power figures, it did meet or exceed all of its real power ratings with a minimum of fuss. The amp ran through our entire line-up of tests without a hitch, which generally indicates a stable, sensible design. Efficiency at 1/3 power measured an impressive 39 percent and overall, there’s a lot to like about the performance of this amp.
Distortion at Rated Output @ 1 kHz: 0.02% THD+N @ 460 watts
Output Power (resistive) minimum output 20 Hz to 20 kHz @ 1% THD+N, all channels driven into 4 ohms: 155 watts x 2 @ 14 volts, 127 watts x 2 @ 12.8 volts, 81 watts x 2@ 10.5 volts
Output Power(resistive) minimum output 20 Hz to 20 kHz @ 1% THD+N, all channels driven into 2 ohms: 214 watts x 2 @ 14 volts, 176 watts x 2 @ 12.8 volts, 111 watts x 2 @ 10.5 volts
Output Power (4-ohm IHF Reactive Load @ 60 Hz to 1% THD+N): 545 watts
I'm running two kenwood amps in my system and one of them is the 9152D your looking at. It's a good amp and i've never had any problems with it going into protect or overheating even on long roadtrips. Alot better quality than pyle would be but maybe not as nice as JL but its cheaper in price than JL
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
amartin_72
