Keep Diamond D3 or upgrade to PG RSD?
kmu
Hi there, I have an alpine amp 400rms @4ohms and 600rms @2ohms.
Got a 12"sealed box with .95cf of airspace
I currently have a Diamond Audio CM3 12" single 4ohm getting 400rms, do you guys think a Phoenix Gold RSD 12 dual 4ohm getting 600rms will sound better? Im looking for SQL specially on the low notes....
THX in advance
Anyone knows how this Phoenix Gold RSD12 would play in a small sealed enclosure?
PG recommends for sealed boxes 1.2cf for SQ and .7cf for SPL, thats strange isnt it that they recommend a smaller box for SPL.
Since Im just in the middle of the recomendation, I guess the sub should perform nice shouldnt it?
I can get the RSD for the same price I can sell my used CM3 12 diamond audio sub, this way I would get the full potential out of my amp...
My PG RSD12D's are getting 900 watts each and they sound great and get pretty loud. They are in ~2.0^3 ft shared.
Thats good to hear, how are the low hz notes on that size enclosure?
I will stuff about 1.5lbs of polyfil to help the sub in such small enclosure
THX again...
I just found out my sub is not a Diamond Audiio CM3 sub but an M3 sub which is much inferior, the CM3 is rated for 400rms and the M3 is rated for 200rms.
I found out because while browsing on diamondaudio.com I couldnt find the CM3 12"in single 4ohm version, the one that comes with a single 4ohm coil is the M3 sub wich is inferior.
So one more reason the RSD 12 getting 600 rms could play better.
kmu
kmu
Tucson, Az...
mr_imperial
