Keep Blowing Fuses !!!
yea the power inverter is designed for things that run off 120V like a wall socket is
most amps only needs like 12-13
but i had this same exact problem b4, and i checked the amp and i accidentaly had the power cable plugged into the ground slot on the amp, and the ground to the power slot. after i realized how stupid i was for doing that and then i plugged them in the right way
First, Why are you running a power inverter?
Second, You need a fuse on the power wire near the Bat going to the amp.
Third, The ground should be grounded next to the amp to the chassis.
Fourth, buy your self a DMM and learn how to use it.
The amp pos. should connect via a fuse to the cars battery pos. NO INVERTER.
The amp neg should be connected to the cars chassis within 18' of the amp or so.
If you hooked the amp up to an inverter and sent 120 volts ac into it at 60htz, then it may be fried. But if the fuses popped, then it may be ok.
Hook it up properly and try not to fail anymore.
OMG this thread is so FIAL. Sorry OP, but if this thread is the realz, then you are indeed a moron. I hope this is a troll thread. However all troll threads should be placed in the Lounge //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
williambrea
DD>AQ
williambrea
Roanoke VA
loopkiller
