JVC KS-AR9501D 1500W RMS, Monoblock Class D Digital Amplifier 1500RMS CEA-2006
krisfnbz
Frederick MD
JVC KS AR9501D 1500W RMS Monoblock Class D Digital Amplifier Great Condition | eBay
Real specs: http://mobile.jvc.com/reviews/JVC%20Amp%20test%20report%2011.08%20v2.pdf
Pics: JVC KS AR9501D 1500W RMS Monoblock Class D Digital Amplifier Great Condition | eBay
JVC Arsenal Single-Channel Monoblock Class D Car Amplifier
Compact design for installation into smaller spaces
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
1 ohm: 1500 watts x 1 chan.
Max power output: 1800 watts x 1 chan.
Pulse-width modulation regulated MOS-FET power supply
Optional remote bass level input (Bass remote control sold separately)
Illuminated blue LED front control panel indicators
Variable tuned Bass EQ (0-18 dB bass boost at 45 Hz )
Single channel monoblock operation
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs
Front mounted controls for easy and convenient adjustments
4-Way Protection against thermal, short circuit, overload, and DC offest
External bridging between two JVC KS-AR9501D amplifiers for an RMS output of 3000 Watts
Heavy duty heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable low-pass filter (50-300 Hz, 18 dB/octave)
Subsonic Filter (18 dB at 20-50 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-300 Hz
Dimensions: 9-11/16"D x 14-1/8"W x 2-3/8"H
Been a member here since 06, DIYmobileaudio since 08, see ebay refs as well. PM me with any questions.
$180 shipped OBO
Google do it translate what ever i do
386
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
krisfnbz
krisfnbz
Frederick MD
krisfnbz
