JVC KD-AR8500 Reception Issue
  • 2
Ridley
The Audio N00bie
I've had this HU for a little over 6 months now and from day one I've had poor reception on the radio. I can never find my local channels and when I do, it cuts in and out. Is this a known problem with this model? Is there a way to fix this issue without taking it back or is it a defective unit?
Thanks for the help!
you sure your antenna is plugged into the HU securely? a loose antenna connection could do it. Also if you have power antenna and don't have the power antenna wire hooked up, that could do it too
I drive a Dodge Neon. Would that have a power antenna?
I had a guy check it out when I first had the issue and he said everything was hooked up correctly.
I'll have a look.
Before I rip this thing apart.... are you aware of any problems with this model? The guy that checked the setup said there are problems with reception depending on which model you choose.
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Its a Hit or Miss on FB.Market Place for buying any electronics. Pull it and wire it up at the vehicles 12v battery to see if it powers on...
943
Ridley
The Audio N00bie
Ridley
Pittsburgh, PA
Ridley
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
