just wondering?
  • 2
97cavy
Albany, NY
I have a zapco AG 350 running my perfect 12''s (well only 1 at the moment, waiting for my replacement from infinity) and i was messin around with my set up today, tryin different placement for the sub, and amp controls. To test how i have my settings, i use a test track that goes from 300hz to 10hz to see how it sounds. I had my amp on stereo, and it sounded nice, then i switched it to mono. It sounded ALOT better at certain freq. but, at some other, it didnt sound like it was good at all. I was wondering that if i keep it on mono, is there anyway to damaging the sub at all with the higher freq? Thanks
Don't worry about high frequencies damagiing your subs. It's the ultra low frequencies that will cause damage to a sub in a ported box. Below the tuning frequency of the port the woofer will start to act like it is in free air. Using a subsonic filter can remove these frequecies and improve the efficiency of your subwoofers.
If you are bridging your amp than you should have it set to mono.
I have a 2006 Mustang GT and the alternator amperage is 135. I'm running 3 amps totalling 1600 amps, driving 2 subs, 4 - 6x8 and 2 - 6.5. Ive...
Ive seen 3 370s in action at a couple Audio shows with a massive battery bank in Austin
4
734
97cavy
97cavy
Albany, NY
indosia
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
