Just installed head unit, radio buzzes but cd works
what year corolla? i dont believe they need an antenna adapter...
does that car have a power antenna? did you hook up the wire on the back of the radio to the car harness?
if you did, could be a somewhat faulty unit, but probably a wire not connected
No amps, i connected the ground wire from the car harness to the one from the unit. If it wasn't grounded correctly it wouldn't even turn on right?
The antenna wire plugged into the back of the head unit fine. Do i still need an adapter?
It's a 93
any other ideas? i have two loose orange wires coming from the car harness. one with a white stripe, one with a black stripe. what are these for?
sorry i guess i should've put this in the wiring section:banghead:
yz134mx
yz134mx
Bel Air, MD
yz134mx
