Just got my Crunch PZN210 in I got off ebay I have no manual. Its 400 watts I will be hooking it up to 2 Kicker Impulse 8 inch subs at 2 x 100watts at 4 ohms.
?s are the setting on the amp I have no idea where to start
LEVEL - 5v to 0.2v...where should i turn the screw? halfway?
BASS EQ - 0db to 12db...where should i turn the screw? halfway?
HPF - 60Hz to 1.2KHz...where should i turn the screw? halfway?
LPF- 30Hz to 250Hz...where should i turn the screw? halfway?
X-OVER-- FULL or LPF or HPF...where should i put that switch?
