just askin'..
renier
Vivo BOoOM .i.(0_o).i.
how can i use two different amplies for the subs?
i have a class D lanzar,for low frequencies purpose only,and a S15L7..
i just want to add up another S15L7 and a high/mid power amp..
1 baric for low freq and 1 for high,mid bass..two boxes,w/ the same size(8cu.ft.)
just need to replace the rca jack for the sub output from the crossover?
i wouldn't recommend running mids/highs through a sub, as the sole-purpose of a sub is to play the lower-end of the frequency spectrum.
if you wanted, get another 15L7, a nice big amp, then get a component amp and just run the power wire from a distro block, jumper the rem wire from the other amp, and run rca's from amp (unless going active, then run from the hu's rca outs).
renier
renier
philippines
dkguitarist
