jm
jmaynard33
i have an AIWA CD player i have installed into a 1996 Ford Ranger and have had alternator problems since. I followed the wiring diagrams on the conversion kit. I did not secure the ground to a metal part of the vehicle, i just wired it up to the kit the same way the original stereo was hooked up. Should i be grounding that wire to metal instead.
i have had to replace one alternator so far and i talked the part people into giving me yet another under warranty. yes my problem was low voltage. jm is my initials, i was in a hurry. it's better than bm
i see your new to the forum but you don't put your intials as a title lol. something is seriously wrong then if you are getting low voltage just from a headunit. are you running any amps?
running amps? not sure what you're asking. i drove the truck with the new cd player in it for a couple of days and noticed it powered itself down and tried to power back up. i then noticed my alternator gauge dip and stay down until i turned everything off but the engine. when i took the vehicle to the parts place they tested it and said my alternator was bad. i replaced the alternator for a pretty penny and was still having the same problems. i put the original stock radio back in last night and have had no problems with my alternator.
No way can a HU give you volyage drops. It's just not possible. The alt can not be damaged by a HU.
judging by that response you probably don't have any subs or amplifiers in your car. something has too be wrong somewhere in your electrical system where a little headunit, drives down the alternator like that. try going to a different shop.
jmaynard33
jmaynard33
kansas city
iceteebone
