A system operator will be with you momentarily. Please understand that there is no foul language while using this service or your session can be terminated. Please also be aware that the operator operates multiple chats at one time and takes customer service calls as well, so if there is a delayed response to your question we apologize and ask that you please be patient while the operator is assisting others and will get back to you as soon as possible.
You are now chatting with 'Scott Johnson'
Scott Johnson: Hello, how may I help you?
Warren: I'm looking into getting the 9510 or 9512
Warren: here's the situation
Warren: I have a 1000.1 JL amp
Scott Johnson: then you would want the 12 for the RMS power handling
Warren: I want to run it on the 9510* if i get it however I think I will end up downgrading amps to the jl500.1
Warren: will the 10 be able to hold the power of 1000 watts?
Warren: b/c i noticed the rms of all the subs are 500-1000
Warren: what's ideal (and i will have a ported set up
Scott Johnson: I can't recommend that it will
Warren: oh really
Warren: why's that
Warren: details please..
Scott Johnson: because I cannot recommend overpowering our product being one of the techs for the company
Warren: i understand that but if the rms says 500-1000 watts and i have a 1000 watt amp how is that overpowering the sub?
Warren: actually n/m the rms of the sub is 750 correct?
Scott Johnson: yes
Scott Johnson: that is why I'm saying not to go with the 10"
Scott Johnson: the 12" will be gine
Scott Johnson: fine*
Warren: ok BUT I'm more interested in the 10.. and i'll explain why
Warren: I have a 13w7 right now I've had it for about 3 years - its too much for me and its time to put more effort into a good sound vs. killing my car. i think a 9512 will sort of put me in the same boat that i'm in now. if i get the 9510 i'm going to have the 1000.1 on it until i sell the amp then i wantedt o get a jl 500.1 to put on it. my i guess my question is "given that you dont' recommend overpowering the sub" will 500.1 be efficient enough for the sub .. how close to the rms do i need to be in a ported set-up
Scott Johnson: Please hold one moment
Scott Johnson: 500 will be plenty for that woofer
Warren: ok now flip my statment for the 12
Warren: 500.1 on a 9512*
Scott Johnson: that would be fine as well
Warren: so what is the point where power is just going to waist meaning one would get same performance no matter power. example: if i had a woofer that had 200 watts rms (there would be no difference in performance if i had 200 watts vs 400 watts besides the risk of blowing it and longevity)
Scott Johnson: you will notice a difference by under driving a woofer
Scott Johnson: but you will be ok
Warren: humm
Scott Johnson: you notice a big diffence when you're able to double the power or double the surface ara
Scott Johnson: area*
Scott Johnson: so going from 1000 to 500 you will notice
Warren: ok so given the information that you have (i have 1000.1 and might get a 500.1) and my interest being 9510 and 9512 which subwoofer will be most efficient w/BOTH amps?
Scott Johnson: 9510
Warren: great
Warren: can i purchase the sub online or do i have to go thru a retailer?
Scott Johnson: you need to go through a retailer
Warren: so i can't call up mtx and get the sub?
Scott Johnson: no, we do not sell direct
Warren: humm
Warren: I have some comments about that but i'll keep that to myself
Scott Johnson: well we can't sell direct and expect our dealers to not get upset
Scott Johnson: you can order from our factory outlet site but at MSRP pricing
Warren: true however your dealers don't promote the loaded boxes that mtx carriers
Scott Johnson: there would be no discount
Warren: dealers perfer to upsale their own custom boxes to make additional profit
Warren: example: called a shop
Warren: asked about sub etc..
Warren: i mentioned mtx's box
Warren: he said no no no
Warren: this happens a lot which i'm sure you're aware of
Scott Johnson: i don't hear about that stuff on my end too much
Warren: probably wouldn't if i dealer i wouldn't tell you either
Warren: keep in mind all they want is the equpiment, they can make up the back end on doing a box
Scott Johnson: would you like the website address?
Warren: nope
Warren: thanks scott
Scott Johnson: you're welcome
Scott Johnson: have a great day
Warren: you've helped me make a good decision - i will post your comments in a forum
Warren: onlinecarstereo.com (subwoofer section under the name limitkid7)
Scott Johnson: as long as it isn't that I'm recommending overpowering the 9500
Warren: you're not
Warren: that wasn't my question
Warren: my question was which was more efficient w/BOTH amps
Warren: you've answered that question
Warren: otherwise if you didn't answer the question you wouldn't be in the support section
Warren: haha
Warren: cya
Warren: whoops
Warren: i have one more question
Scott Johnson: yes
Warren: its a box question
Warren: i saw there were volume specs given on the site
Warren: but i can only assume those specs are for a 750 watt amp which is stated to be the rm of the 9510
Warren: considering that i'll have less power to drive the woofer ~500 watts underrated
Warren: what size do you recommend i go for the box given i'm 250 watts under the rms
Warren: *in slot ported box of course
Scott Johnson: i would use the same specs
Warren: so you wouldn't say larger box given the amount of watts?
Scott Johnson: the different wattage is not going to change the parameters of the woofer
Scott Johnson: no I would not
Warren: larger box allows air to move easier
Warren: in a ported box correct?
Warren: or is my assumption wrong
Scott Johnson: it changes the suspension
Scott Johnson: use the same box specs
Warren: k
Warren: oh really
Warren: why's that
Scott Johnson: yes
Warren: humm
Scott Johnson: 9510
Warren: great
Warren: humm
Warren: nope
Warren: you're not
Warren: haha
Warren: cya
Warren: whoops
Scott Johnson: yes
Warren: k
