jl xr653-cs
JeepComanche
I have been wanting to get rid of my comps in the rear of my truck and the coax's I have in my doors and in replacement build a custom enclosure for my sub and mount my amps behind my seats which would interfere with the sound from the comps, for I drive a jeep comanche and is very tight for space behind the seats. And replace the fronts with a set of these run off an external amp.And then shut the internal amp off on my deck to combat dash heat. I would like to know what people thought of these speakers and whether or not my ideas for setting them up would work out allright.
I plan on putting the bass drivers at the bottom of the door, the tweet in the little panel by the door handle and the mid in the bottom dash where the speaker grille is located by the door. Any opinions would be appreciated.
And getting rid of the rears because alot of sound gets redirected and blocked with the current setup and that box is too small for my sub need to build a bigger box so it will be even tighter
Thanks for any info or suggestions:)
JeepComanche
JeepComanche
bc canada
JeepComanche
BP1Fanatic
BP1Fanatic
