* JL W7 Box Specs!?
1.5ft^3 tuned to 56hz?
Actually, closer to 54Hz, but yes. You have to remember, that the tuning frequency is not in direct control of the response curve. Its very subjective towards cabin gain as well. The recommended was based on a smooth response only, also that it can be minorly tweeked using more information about what mat be requested. Remember, this is optimal recommendations, not "tuned" to a specific goal yet. Just a starting point and will only be that until more information is needed, which can change the entire outlook and numbers.
What about a 12W7 3ohm SVC, can you crunch those for a homie
8 have 1.34 cubic ft, 12.5x4.75,66.75"port.
You guys have to remember, that again, these are sq recommendations, not spl, or sql. Just what the drivers like, not what we like. A common ground can be met for more personal oriented response. Most will find these numbers not to their liking....mainly because they are not used to it.
This one should be around 40Hz or so, haven't figured for tuning yet.
As far as the first one for the 13.5, it should be 81". It didn't hit the 2 on my calculator. Lol. But still, 54Hz is good for SQ, Ill stand by that,lol. Not sure what 81" Gives you though. It should be around 38Hz or so, not sure...if someone wants to use one of those simple calcs for it.
Another note....my box volumes are smaller than manufacturer recs because of compression factors that they do not consider. Do not let the box volume control the output or loading, let the port do the work it is intended for. The compression is mainly for coupling and driver control, then the phase and main output of vlf response is done by the port. Making a box too large with a small port will have less driver control and less tonality than a smaller enclosure with a proper port. Don't control tuning based on mainly box size. Just a thought. Of course, everything works hand in hand, but the physics are constant. This was the whole reason I believe bose took that info from jensen, for the wave radio. And tline became a thing again, because of proper loading of a resonance tube.
Sorry, just needed to say that.
I've had 2 in 2 different ported boxes. One was in a smaller ported box, not quite sure what the tune was but the sound didn't compare to the other 13w7 in the larger ported box. The other one was in a 3.5 ft^3 @ 35 and sounded pretty good but imo if it was tuned a little lower to maybe 32 or 33, it would've definitely sounded better.
The OP asked me to do a comparison of my specs and the 2.5 box. I used 33hz for the 2.5, and mine is not figured using a tuning factor, just proper alignment. This is how close the two are in response:
Here is the anechoic responses
Here is the response with an example vehicle gain
This shows that both of them are pretty identical, with mine not focusing on tuning, but proper loading and coupling. The difference is, my enclosure exhibits a shallower delay from 30-60Hz, resulting in a quicker response time for multiple tones within a certain period. This means, the tones are separated by the ear better and not blended from delay time. Also, it is more in phase from 31-90hz, vs the 2.5 which has a 90degree in phase response from 35-95Hz. What does this tell you? That from 35hz and below, my specifications will also result in more direct output for the previously mentioned less delay time. Hence, more accurate output.
One more thing is that the optimal loading frequency, though it will not show up in the response, for my design is at 37Hz, and for the 2.5 design is higher at 42Hz. This is the result in higher +3dB output shown in the graphs from 32Hz and below, though at those frequencies, that is nothing audible, but mentioned because it is related to the loading of the design, showing that mine has a lower frequency loading capability for higher efficiency. Not by much at all, very close, but the point is, my design was not based on tuning, but loading. And it compared quite well with minor/better results in quality.
I had to show this because the OP requested this in a PM and I wanted to post it here so people will see that a bigger box is not always better. In fact, in this case, it is very close to what my recommendations are, so I give much credit to JL for having those specs...which proves again why some of you say they are very well specifications. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It also must be noted that my recommended port area was used for both designs. And any smaller port area would result in the JL 2.5cft box to have a drop in response quite a bit for nearly the entire usable range, but will give better quality and a smoother phase than before. So, it is a compromise as always. Hope this helps for those who questioned my recommendations.
Thanks, and sorry for thread jack but my goals are not spl, I just want to hit the lows and not be peaky. more a deep bass sq
YW. PM me then. I can get you a more deep bass output if you like. No problem. Keep in mind, I am not finishing the design for you. I only did this for free to help you all out, and gain some recording information in the process for later calculations to make them more accurate if possible. SO, pm me and I can help you out more with a design idea more towards your request.
Kastlez_
Kastlez_
Bay Area, CA
Kastlez_
