Jl Hd600/4
u1cracka
I bought a JL HD600/4 amp and need some help.
I hooked this amp up and the power light flashes from green to red and no music.
I disconnected my RCA's and the light stood green so i thought i had a bad RCA's and try-ed a different pair but it did the same thing.
So then i now tell my friend to pull his car up to the side so i can hook the RCA's to his Alpine IVA-W205. WE hook it up and the amp works perfect so i think great it must be my new Pioneer Premier FH-P800BT double din CD player.
So I figure what the hell I go and get my old JL 300/4 and hook it up in my truck and to my Pioneer Premier FH-P800BT and it works perfect so now I am like what the hell why does the JL 300/4 work with my deck and the JL HD600/4 wont work with my deck.
The only difference with the Alpine IVA-w205 is it has 2volt pre outputs and my Pioneer Premier FH-P800BT has 4volt pre outputs would this make the JL HD600/4 amp not work.
U1cracka
Alternating Red and Green: lights to indicate
that the amplifier is experiencing a fault
that may require service of the amplifier, its
wiring or the vehicle’s charging system. Audio
is muted when this fault occurs. The most
likely cause of this fault is a low supply voltage
condition. If battery voltage drops below 8.5
volts at any point, the amplifier (except for the
“Status” LED) will shut itself off to protect itself
and the vehicle’s charging system. If the voltage
drops below 6 volts, the “Status” LED will also
turn off.
Alternating Red and Green: lights to indicatethat the amplifier is experiencing a fault
turn off.
Yes that's what it says in the Manual.
It is not that problem that the manual says because the amp will work if i hook the RCA's up to my friends deck It just wont wont with my deck but my old amp works with my deck perfectly
Thanks
U1cracka
re check the ground
the RCAs
how you had the speakers wired
maybe one connection on the speaker fell of, or you ended up with one schannel having + and - wrong
re check the groundthe RCAs
I checked all that and all the speaker wires are conected
also when I tryed it with my freinds deck the amp was still mounted in my truck we only ran rcas to his radio.
Thanks
u1cracka
u1cracka
u1cracka
Hawaii
u1cracka
