JL Audio -Vs- MTX
I love both subs. But I feel the 9500 does fairly well in the SQ department w/ the proper enclosure. The 9500 will get louder and sound just as good as the W6 maybe a little less.
iv ran them also i doubt it, they can get 1k and thats about it at 12.5... lol i bet he has no backup power or anything and i ran mine on near 15 volts in perfect conditions and its powerful but not over 1k, a 1000/1 has more power.... i picked up .5 dB on the same 13w7 when i switched to the 1000/1
ignoance is bliss //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
81000 = 1501 = way WAYYYAAYAY more than 1k
kthxbi
umm no, first off because your "birthsheet" said that i bet you didnt get that out of it and secondly iv ran a ton of W6's back when i loved JL, i ran one in the HO box JL SOLD IT WITH and ran it on a 1000/1 with gains set correctly and after no more then 20 days it fried
go to ROE and the great 12 challenge, read up on their results, for music its bad to run even over 900 rms and they fry at the 1k mark
UMM, YES *******. THAT AMP PUT OUT 1345 WATTS AT 14V ACCORDING TO LANDIS TECHNICAL WHEN I HAD IT REPAIRED DUE TO SOMEONE TRYING TO STEEL IT. I DONT GIVE 2 SHITS WHAT ROE HASE TO SAY, I KNOW WHAT IT DID AND IF YOU GET YOUR BIAS HEAD OUT OF YOUR *** YOU WOULD KNOW THAT AMP PUTS OUT RATED POWER AND THEM SOME. KNOW WHAT YOUR TALKING ABOUT WITH EXPIERENCE BEFOR YOU OPEN YOUR MOUTH(OR KEY BOARD)
kthxbi
Wasn't that only on the modded models?
modded you can go up past 14.4v
i'm talking 12v range. rated at 1000 @ 2ohm @ 14.4v IIRC
shit's a beast. VERY under rated. i'll put my 1501 up against a 1000/1 all day long
1501d's are very nice amps, I won't argue there. Great build from them back in the day.
rofl biased? iv ran all this gear that has been brought up and iv ran all the bs gear you have quoted and brought up on proper electrical + some and i dont run any of it any more fyi
I have a 9500 and never had a problem with a cracked cone. That's why you don't bump with stuff sitting on your cone lol. As far as SQ; it doesn't have any. It is very loud though and can move some air.
If you didn't type in all caps it might help your argument. Just an //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
agreed but not these lines being compared
edit:yea rofl the 8100d does 1K and like 1.5 modded, ignorance is bliss
MTX Site LINK
Code:
Specifications
Power 12.5 VDC
2 Ohm Load 	1000 w x 1
4 Ohm Load 	500 w x 1
Power 14.4 VDC
2 Ohm Load 	1500 w x 1
4 Ohm Load 	850 w x1
joo = don't know wtf you are talking about. and those are very very modest ratings
Gagt518
Soon To Be Heard
Gagt518
Albany,NY
R/T Pimp
