JL Audio J2 360.2
agarabaghi
JL Audio J2 360.2 Full Range AB Amp
Basically new, was mounted once and powered on. Few scratches on mounting screw holes, all coesmetic
10/10 mechanical
9/10 cosmetic since it was mounted
J2-360.2
2-channel Class A/B Full-Range Amplifier, 110 W x 2 @ 4 Ω / 180 W x 2 @ 2 Ω - 14.4 V / 360 W x 1 @ 4 Ω Bridged
J2 Series 2-Channel Class A/B Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 110 watts x 2 chan.
3 ohms: 135 watts x 2 chan.
2 ohms: 180 watts x 2 chan.
Bridged Power Rating (14.4V):
Bridged, 8 ohms: 220 watts x 1 chan.
Bridged, 6 ohms: 270 watts x 1 chan.
Bridged, 4 ohms: 360 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +9 dB bass boost at 50 Hz)
Soft Start Turn-on
2/1 channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Silver-plated RCA level inputs
Silver-plated screw terminals
Input sensitivity:
Low level: 200mV-4V
High level: 2V-10V
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (50-500 Hz, 12 dB/octave)
Frequency response: 10-35,000 Hz
Dimensions: 12-13/16"L x 9-5/8"W x 2-3/16"H
$80 shipped to US
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
