solarys
Which amp would better suited to power a JL Audio 13W7 sub? The JL Audio HD 1200/1 or the JL Audio Slash/v2 1000/1v2. Any/all suggestions are welcomed.
the hd is a better amp imo, and should have more power.Which amp would better suited to power a JL Audio 13W7 sub? The JL Audio HD 1200/1 or the JL Audio Slash/v2 1000/1v2. Any/all suggestions are welcomed.
Nicely put.Hi Solarys, R0llinLacs wrote:"I haven't had a chance to hear the HD1200/1 yet, but the other HD amps sound amazing. Distortion is a mere .03% at rated power, compared to .05% on the 1000/1. Also the 1200/1 signal to noise ratio is 111db, compared to 105 on the 1000/1. I can almost guarantee the 1200/1 will be louder and cleaner, so to answer your question, the 1200/1. The sub will handle 1500wrms, so 1200wrms will be louder and cleaner than 1000wrms any day."
Here is my view on this, I have a Fosgate amp now (I'm over 30 yrs old & had MANY systems.) I have owned & used the following amplifiers: JL 1000/1v2, JL HD750/1, and JL 500/1v2. I love JL amps, but my RF T1500-1bdCP has a good bit more output due to my strong charging system giving it amperage it needs to get to 1,900 watts at 1 ohm. (birth sheet says 1,908). Now I'm aware you have a 13w7, and those are top-notch, so yes you want a nice JL amp to go with it.
Without a doubt, I honestly recommend the 1000/1v2, if you have the room... and here's why. Now the HD1200/1 is a nice amp, don't get me wrong, but it has no bass boost! (the remote is simply a gain control) The Slash amps are MEANT to dish out power under hard constant use, and their Bass EQ's let you control the sub much more. With the HD's, I really don't think the Single Cycle control really enhances the damping factor much more than the already very high factors in the Slash amps. And 2 hundredths of a percent in "distortion" amounts to absolutely nothing, and the slightly higher STN ratio doesn't mean much when you are talking subwoofer frequencies... you simply won't hear the difference.
Here is my personal experience. I had the HD750/1 running 3 JL 12w1v2-8's in the JL powerwedge enclosure in my SUV. It was ok, sounded clean, but I couldn't make it HOUND... all i had to play with was the lame gain control, so I returned it and used my 500/1v2 from my camaro, just to compare them. The 500/1v2 made it noticably louder, especially in the deeper frequencies below 45 hz, and this is a SEALED enclosure!. So I got the 1000/1v2, and MAN, a HUGE difference... the subs were going to jump out of the box with that amp, so I sold my three 12w1's, and got four 10w3v3-4's (wired them to 4 ohms final). It really sounded good & LOUD, and pleased me for a while, until I started wanting more power (car audio is a disease, lol). I snatched me up a Fosgate 1,500 watt RMS amp, wired the 4 subs to 1 ohm (JL is not stable there) beefed up my charging system, and now each 10" sub is getting about 475 watts with this hoss of an amp. (amp is unregulated & under-rated... class B/D).
JL should really make a bigger amp that is at least 1,500 watts RMS, or put bass EQ's with remote boost on the HD amps. If you think of how big a SLASH amp is, do you really think you're going to get the same output when they cram all the components into a HD chassis? My 750/1 got pretty dang hot, even running that 2.7 ohm load. I honestly don't recommend running any JL amp at 1.5 ohms for extended playtime, even the Slash amps.
To sum it up, the 1000/1v2 is huge, but it will give you a little more ummpphh than the HD1200, but if the 1200 had actual bass boost, then it'd maybe be slightly louder, but you still have to worry about it overheating, being that compact (same exact size as 750/1), and I wouldn't run it at 2 ohms or below for hard, heavy bass. Don't doubt the dinosaur!
The crap in my car: Alpine head unit, RF T1500-1bdCP amp (2010 model), four JL 10w3v3-4 subs in sealed enclosure, earplugs
IF you can wire 4 subs to 1 ohm THEN you can wire 4 subs to 4 ohms where JL is stable hence why they made it 1.5 - 4 for flexibilityHi Solarys, R0llinLacs wrote:
