Sold JL Audio e1200 $65 shipped...
clbolt
I'm Bad, I'm Nationwide.
I have a JL Audio e1200 for sale. It's used, not abused, works great, but it has the typical scratches from having it in the back of my wagon. It'll fit easily under most seats, and it drove the he!! out of a pair of Fosgate HE series 10s without ever getting hot. $65 shipped CONUS, PayPal only. PM if you're interested.
Absolute Symmetry™ Class AB Circuit
(U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
Accept up to 8 AWG wire
+12V and Ground connections:
Accept up to 4 AWG wire
Specifications
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V);
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm / 50 Hz,
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
clbolt
clbolt
Arkansas
clbolt
