Durry
in your opinion which set of speaker comp are better?
Here are the specs
JL C3 650
6-1/2" Evolution Series 2-Way Convertible Component Speaker System
Power Handling:
Peak: 300 watts per set / 150 watts each side
RMS: 150 watts per set / 75 watts each side
Recommended RMS: 25-75 watts each side
Quickly converts from coaxial to component system
Phase plug replaces tweeter assembly in component system mode
Impedance: 4 ohm
Top-mount depth: 2-9/16"
Frequency Response: 48-25,000 Hz ± 3 dB
Sensitivity: 93 dB
Efficiency: 90 dB @ 1W/1m, 96 dB @ 1W/0.5m
Polk Audio mm6501
Oversized 6-1/2" (6-3/4") Polk Mobile Monitor Series Component Car Speaker System
Power Handling:
Peak: 500 watts per set / 250 watts each side
RMS: 250 watts per set / 125 watts each side
Woven glass composite cone woofer
Butyl rubber surround
1" Silk composite dome tweeter
Use of space age materials result in weight reduction, rock solid reliability, advanced looks and ultra high performance
Carbon composite basket
Klippel distortion analyzer
Marine certified
2.7 ohms impedance
Neodymium magnet
Top-mount depth: 2-5/8"
Here are the specs
JL C3 650
Power Handling:
Impedance: 4 ohm
Sensitivity: 93 dB
Polk Audio mm6501
Power Handling:
Marine certified
2.7 ohms impedance
Neodymium magnet
