Jl audio amp getting very hot when used, Advise needed..
richiemkk
Hi All
Need some tips to source the cause of my door speaker amp getting seriously hot to touch when running for a short time , I have the following amp>
JL audio slash 300/4 >
Frequency Response5 - 30000 Hz
Signal-To-Noise Ratio108.5 dB
Continuous Power / Channel Qty75 Watts x 4
Amplifier Output4-channel
Input Signal Voltage0.2 - 2V, 0.8 - 8V
CrossoverActive crossover
Amplifier ClassClass AB
Distortion Factor0.03%
Amplifier Output details75 Watt - 1.5/4 Ohm - 4 channel(s) 150 Watt - 3/8 Ohm - 2 channel(s)
FeaturesInput level controls, thermal protection, subsonic filter, short circuit protection
Only running about half the output level on 2 rear 6x9 100w rms speakers and 2 front 90w rms 6.5cm .
Earth is 4 gauge to the seat belt mount ( very clean ground) (Biggest the amp will take )
Live is a 2 gauge from battery that splits down to the amp input size via a fuse block 4 gauge ..
the live comes to the boot and is shared with my mono block amp for the subs. ( this doesnt get hot ) Can give more info if required ..
Any help very useful chaps .
Cheers Rich
richiemkk
richiemkk
London
LosIsATool
