Sold JL Audio 500/5 Channel *MINT* Lowest price yet!
King$nake
No Reserve!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270204744034&ru=http%3A%2F%2Fsearch.ebay.com%3A80%2Fsearch%2Fsearch.dll%3Ffrom%3DR40%26_trksid%3Dm37%26satitle%3D270204744034%26category0%3D%26fvi%3D1
Specs:
Description: Hybrid Class D & Class A/B Five-Channel System Amplifier
Patented Technology: High-Damping Class D Circuit with discrete control circuitry (U.S. Patent #6,441,685)
Absolute Symmetry™ Class A/B Circuit (U.S. Patent #6,294,959)
Differential-Balanced Input Topology: 3 pair of inputs
Front Crossover: Fully-variable (50 Hz - 5 kHz), selectable-slope (12 or 24 dB per octave) BP or HP
Rear Crossover: Fully-variable (50 Hz - 5 kHz), selectable-slope (12 or 24 dB per octave) HP
Subwoofer Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Preamp Output: 2-channel (pass through or tracking LP)
Bass EQ: Variable boost up to +15dB and Remote Bass Option
Infrasonic Filter: Defeatable 24dB/octave at 30 Hz
Left Minus Right / Right Minus Left Ambience Circuit: Ambient effect for rear channels
Front and rear speaker output connections: Accept up to 8 AWG wire
Dual mono subwoofer output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
500/5
Rated Power Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio (Front & Rear Channels): >108.5 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
S/N Ratio (Subwoofer Channel): >95 dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response (Front and Rear Channels): 5 Hz - 30 kHz (+0, -1dB)
Frequency Response (Subwoofer Channel): 5 Hz - 300 Hz (+0, -1dB)
Damping Factor (Front and Rear Channels): >200 @ 4 ohm / 50 Hz
Damping Factor (Subwoofer Channel): >500 @ 4 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 19.70 in. x 9.25 in. x 2.36 in.
500 mm x 235 mm x 60 mm
Additional Information about Jl Audio 500/5 Car Audio Amplifier
Product Information
JL Audio has to be commended. They have produced one of the most efficient amps on the market bar none! What is so impressive is that they sustain the same RMS power Ratingthough the ohms spectrum.
Product MPN
MPN 500/5
Key Features
Amplifier Type Multi Channels
Bridgable Bridgable
RMS Power at 4 Ohms 100 W x 4 + 250 W x 1
RMS Power at 2 Ohms 100 W x 4 + 250 W x 1
Performance
Frequency Response 5 Hz - 30000 Hz
Signal to Noise Ratio 108.5 dB
THD at Rated RMS Power 0.03 %
Crossover / Equalizer
Bass Boost With Bass Boost
Bass Boost Frequency 48 Hz
Low - Pass Frequency 50 Hz - 5000 Hz
High - Pass Frequency 50 Hz - 5000 Hz
Other Features
Input Voltage 11 volt
Dimensions
Width 9.25 in.
Depth 19.7 in.
Height 2.36 in.
King$nake
King$nake
Rancho Cucamonga, CA
blackbonnie
