Sold JL Audio 500/1
WildcatNate
**** in a Box
Alright, I've got a JL Audio 500/1v1 I need to sell. I am replacing it with an amp I am purchasing from assman...one of his many //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. It is posted below, I took pics with my name and date. Let me know if you have any questions.
I did buy it from a guy on here and it ran great for the 2-3 months I used it. It is a great amp, I would keep it but I need a bit more power. It was running two 10 jlw6v2s.
Edit: 500/1 $230 shipped.
300/4 $75 shipped SOLD!!!
2 12w1v2s $100 plus shipping for both. SOLD!!!
I am in Kansas City and would ship UPS. If you live in KC, we can meet as well and I can take some off for not shipping it.
* Rated Power: 500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power:
* S/N Ratio*: >95dB below rated power
* Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
* Differential-Balanced Input Topology: (1 pair of inputs)
* On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
* Bass EQ: variable boost up to 15dB
* Infrasonic Filter: Fully-Variable 24dB/octave from 15-60 Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual mono speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
I also have a 300/4 that I had problems with, so I would consider it broken. I always got bad distortion on my right side speakers and one of the indicator lights did not work. I took it apart and found out why the light didn't work, but nothing on the issue. It also had some problems with the screws not tightening. I took them all out and ordered new ones, but they never came in. So, if someone wants it, I'd do $75 shipped. For parts or something, don;t know why people buy broke amps, I am not that smart //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
TTT,
I also forgot about two 12" w1s that I have from a while back. I could sell them for $100 plus shipping for both. Also, I can get pics of them or the other amp if needed.
yeah they are the grey ones...the v2s. Sorry I forgot to post that. I will double check when I get home from work, but I am 99% sure they are 4 ohm version.
Great, when you check if they are 4 ohms pm me a price shipped to 50516. I had the 8 ohm ones in my monte and loved them. Thanks
WildcatNate
**** in a Box
WildcatNate
Kansas City
WildcatNate
