HAD THIS AMP IN MY CAR RUNNING A W6v2 AND IT POUNDED!! JL MAKES EXCELLENT AMPS, AND WHEN YOU PAIR THEM WITH THEIR SUBWOOFERS, YOU ARE GUARANTEED A SYSTEM THAT CAN BLOW ALL OF YOUR FRIENDS OUT OF THE WATER!!
Power- 500 Watts RMS
THD- 0.05%
S/N Ratio- 95dB
Freq. Response- 5 Hz - 500 Hz
Damping Factor- 500 at 4 ohm
Input Range- Switchable 200mV-2V to 800mV-8V
Dimensions- 13.4" x 9.25" x 2.36"
Differential-Balanced Input Topology
On-board Crossover- fully-variable 40-200 Hz, selectable-slope LP 12 or 24 dB per octave
Preamp Output- 2-channel
Bass Equalizer- Variable boost up to 15dB
Infrasonic Filter- Fully-Variable 24dB/octave from 15-60 Hz
Signal-Sensing Turn-On- able to turn on without remote lead
Speaker connections- Accepts up to 8ga. cable
+12V /Ground connections: Accepts up to 4ga. Cable
$260.00 shipped
THD- 0.05%
S/N Ratio- 95dB
$260.00 shipped
