JL Audio 12w6v2 with bad surround
evilmonstertruk
Premium Member
Premium Member
JL Audio 12w6v2 with bad surround. Trade or make offer
12W6v2-D4
W6v2 12-inch Subwoofer Driver (600 W, dual 4 Ω voice coils)
Big, powerful bass performance combines with spectacular sound quality in the 12W6v2. Several technologies shared with the flagship W7AE's provide advantages in motor linearity and suspension behavior, which lead directly to reduced distortion and outstanding dynamic balance.
The 12W6v2 is best used with amplifier power in the 200W - 600W range and is optimized to operate in a 1.25 cu. ft. (35.4 l) sealed enclosure, or a 1.5 cu. ft. (42.5 l) ported enclosure. Detailed enclosure recommendations can be found in the "Specifications" tab.
Greater excursion capability and higher power handling distinguish it from our 12W3v3 subwoofer 12-inch subwoofer driver, allowing for higher output. Dual 4 Ω voice coils permit deploying the W6v2 as a 2 Ω or 8 Ω driver.
It has a bad surround . Apparently they all do it after a while. The replacement surround is supposed to be better made so it shouldn't do it again.
http://www.amazon.com/gp/aw/d/B00CRIZW8I/ref=redir_mdp_mobile/181-0365281-6502135
I will post pics of the voice coils with a DMM attached. But will be tomorrow . 9v battery died. But they are fine .
$100.00 obo
Let me know if you have any questions.
Thanks
Sent from my Nexus 6
if you use a blow dryer and heat the dust cap / skin thing up it should pull apart a bit easier. then you can see the part that would crack. in the air flow grooves of the cone. sorry i didnt mean to downplay your sub because it's nice and i could be wrong. if you want help i can try to help you recone that by an instructional if you have never done one. i can tell you where i messed up lol. and if you need parts i can find a lot of stuff that most people can't.
evilmonstertruk
Premium Member
Premium Member
evilmonstertruk
Maryland
Bain
