Sold JL Audio 10w7 IN JL High output box NJ
cecilcohen
NJ
Looking to sell my JL Audio HO110RW7 - JL Audio Single 10W7 Sub in High Output Enclosure Asking $500 for local pick up only IN NJ Tri State area. Ill hook it up and you can hear it for yourself. This was over $800 new.
Specs
Power Handling:
500W Continuous
Drivers:
One 10W7-3
Final Impedance:
3 Ohms Mono
Dimensions:
15.25"H x 32.00"W x 19.25"D
Notes:
Chamber-coupled,
slot-ported enclosure.
Rear-firing design. Available in Gray or Black finish (both with fire-red inserts).
These are insanely powerful "H.O." (High Output) systems designed around JL Audio's flagship W7 subwoofers, delivering very high SPL while retaining excellent sound quality.
Each is properly sized and tuned to the optimum ported alignment for the12W7, 10W7 and (coming soon) 8W7 and is shipped wired, loaded and ready to install. All models use our patent-pending, chamber-coupled port design. The slot-port wraps around the inner enclosure and terminates just above the woofer. This provides the necessary surface area and port length to maximize the performance of the W7メs. The recessed mounting baffle also provides protection for the woofer.
cecilcohen
cecilcohen
NJ
cecilcohen
