Sold Jl Audio 10W6V2, Rockford Fosgate Power 1051S
cgndhhh
Hey guys I know I do not post alot on this forum but I am trying to sell some leftover audio stuff i have left. First up is a slightly used Jl Audio 10W6V2. It was installed in the box you see in this thread and was powered by one of the channels on the amp i have here for sale as well. I had the gains turned way down and i never cranked the subwoofer to its full potential. There are no scratches on the subwoofer and the only thing i can see is a small cosmetic SCUFF mark on the cone. It is not a scratch or crack or anything like that. I have references on ebay and I can take cash if u r doing local pick up or I can take paypal. The subwoofer i am selling for 125 + shipping OBO. I'll only charge you actual shipping costs, which should be around 15-25 bucks. I do have the original box as well. If you have any more questions let me know.
Next up I have a Rockford Fosgate 1051S 2channel amplifier. the amp puts out 525 watts RMS X2 at 2 ohms and 1050 X1 @ 4ohm watts. THe amp has no major scratches was kept clean, never died or blew anything. It did get a lil hot one time and i had to cut off one of the plastic sleeves from the amplifier connections. Amp still works great. I am asking $150.00 + shipping OBO. Any ?'s just let me know thanks
Specs of the amp:
265 watts RMS x 2 at 4 ohms
525 watts RMS x 2 at 2 ohms
1050 watts RMS x 1 at 4 ohms in bridged mode
4-ohm stable in bridged mode
stereo or bridged mono output
Tri-Way capable
requires 4-gauge power and ground leads plus a 100-amp fuse and fuse holder — wiring and hardware not included with amplifier
variable 50-250 Hz high-pass/low-pass crossover, 24 dB/ octave
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp
NOMAD advanced protection circuitry monitors temperature, voltage, current and impedance, and provides "intelligent" shut-down protection without limiting system performance
*****•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation preamp outputs
17-1/8"W x 2-3/8"H x 9-7/8"D
Lastly I have my old box that I built myself when. It used to hold 2 10w6v2's and the amp im selling. Specs on the box are as follows. Outside measurements: 51" long, 17 inches deep/wide, and 21 inches high. The center has a top shelf to display one of ur amps and in the bottom is a compartment to hide any wiring or addt'l amps. The top shelf measures 11" wide, 16" long, and 3" high. The bottom shelf measures 11" wide, 16" long, and 14"high. The cu. ft. of the subwoofer enclosures measure about 1.2 cu. ft. and the slot port measures 1.5" wide and about 25" long. The face of the subwoofer enclosure has a plexiglass window so that you can view inside the box. I finished the inside of the box in white so that the neon would reflect the best. I spent about 200 bucks alone on the box for materials. I am letting it go for 25 bucks, local pick up only.
cgndhhh
cgndhhh
Rosemead, California 91770
GreenToker0420
