JL Audio 1000/1V1
bigguy2010
SQ
736
MI
Title
1 pair of Differential-Balanced Inputs
Fully variable on-board crossover: (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
2-channel Preamp Outputs: independent active filter, parallel with amp filter or full-range
Bass EQ that is parametric with variable bass boost up to 15dB and you can use a Remote Bass Control (optional RBC-1)
Fully variable Infrasonic Filter: 24dB/octave from 15-60Hz
Output Polarity Reversal switch allows instant output polarity reversal
Dual mono speaker output connections that accepts up to 8 gauge wire
12 volt and Ground connections accept 4 gauge wire or 2 gauge or 1/0 gauge
Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V)
THD at RMS Power:
S/N Ratio: >95dB below rated power
Frequency Response: 5Hz - 500 Hz
Damping Factor: >500 at 4 ohms /50Hz
Input Range switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
$450 Shipped.
bigguy2010
SQ
bigguy2010
MI
bigguy2010
