6.5LDiesel
Im running a 12w6v2 in a 2.15cft box sealed running 4 gauge knukoncepts wire.
I bought the subwoofer and amp used for a good deal, the sub is in mint condition without a scratch and the amp looks like its been beaten a bit..
Only issue with the amp as it turns on, plays music well and doesnt get hot or shut off(thermal) is with the 12/24/off db switch. If i switch it to off, the subwoofer plays, if I switch it to 12db it will not work (no sound) If I switch it to 24db it will work only if you play around with the switch a little bit. If i hit a large bump it will stop playing and have to play with the switch again.
I am assuming this switch is bad and is it to possible to replace this? Id just like it to work, if it is possible to do with solder skills and if i need a correct type of 3 position switch.
Thank you
Thank you
