JL 300/2 "Low ohm" light: What does this mean?
FSUNole17
I bought my JL 300/2 about 4 years ago and it has been working flawlessly for a long time. Not too long ago, my speakers started sounding awful and I couldn't figure out why. I started with the amp and noticed that the "low ohm" light was coming on. What could this be? Do these amps have this common problem? I hooked up an old school RF Power 350 amp to the speakers and they sounded great, hooked the JL amp back up and they sounded awful. I don't know if the amp is broken or not, but that low ohm light comes on and I am wondering if there is something that I could do to fix it without buying another amp. Any input would be appreciated. Thansk!
If you connect a load higher than 4Ω nominal per channel in stereo mode (or 8Ω in bridged mode), power will drop by half with every doubling of impedance above 4Ω stereo / 8Ω mono. If you connect a load lower than 1.5Ω nominal per channel in stereo mode (or 3Ω in bridged mode, the amplifier protection circuitry activates a “safe” mode which reduces amplifier power to protect the circuitry from failure (the yellow “Low Ω” LED lights to indicate that this has happened). See page 10 for details.
http://mobile.jlaudio.com/products_amps.php?amp_id=437
Click on the manual.
Drifter, for over 3 years this was not a problem and then all of a sudden it started happening, so I know that isn't it. I have been running the same 3 ohm Boston Pros the whole time as well. Anyone else have any suggestions? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I don't know what caused it but all you asked is what the low ohm light mean's and that's exactly what it mean's. Check the ohm load your amp is getting. Something with the speakers might have went bad and it might be altering the ohm load. The reason it sound's awful on the JL is because of the Low Ohm Load Protection which it says put's it in a safe mode to limit the power they receive. That Rockford you tried doesn't do that so that is why they sounded fine. All I really know to tell you is to pull out the DMM and check the ohm load on the amp. On another forum someone had a similar problem and someone from JL told him to power the amp up without ANY speakers attached. If the low ohm light still come's on without speakers attached then it's a problem with the amp.
What he said! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
FSUNole17
FSUNole17
franklin, tn
Mass Car Audio
