Jl 250/1
dbeez
JL 250/1
Rated Power: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio*: >95dB below rated power
Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 10.25"L x 9.25"W x 2.36"H
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
$145 shipped
included
dbeez
dbeez
crestwood,ky
dbeez
