JL 10w6V2 sounds like crap !
TXslade
Need some help guys ,
I just installed an MTX 600/1 amp and a 10w6v2 in my range rover.
I was upsold from two Boston 10" G2's in boston's own factory box with the expectation from the sales guy that 1x10w6 would pound harder.
Turns out once installed the sound quality is horrible.
from 40-80 hz, its incredibly loud and boomy, totally unresponsive and muddle with virtually no "hit"
above 100 hz, there is a total drop off in SPL. absolutely zero midbass.
ive screwed around with the crossover knobs on the amp and positioning of the box etc with little results.
its a prefab pro form sealex box ~1.2 cubic feet which i know is nearly twice the recommended size for this speaker, but im shocked as to how the speaker will basically refuse to play anything between 100-250hz.
When i called the installer, he immediately tried to sell me a custom enclosure and/or fiberglass enclosure.
i was like wtf ? i already spent a couple hundred more than i expected and now you're hitting me up for another 500 ?
thoughts ? help please !
- a
2007 range rover sport supercharged with KH logic 7 system.
Line out from factory amp to MTX running bridged at 2ohm.
1. Output wise it probably isn't going to be as loud 1 10" vs. 2 10's
2. As was said get a new enclosure. The w6v2 is one of the better sounding subs I have heard
3. WHY OH WHY on gods green earth do you want a subwoofer playing 100-250hz ?????
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
1. Output wise it probably isn't going to be as loud 1 10" vs. 2 10's 2. As was said get a new enclosure. The w6v2 is one of the better sounding subs I have heard
if so, buy a si vag v4
So after speaking with the shop manager, he offered to replace the box and sub with my original idea of either the two 10" G2's or single 12" G2's from Boston in the boston sealed enclosures.
ive done some research and searching around the G2's and looks like they are overall a pretty decent sub for the value.
what is everybodies impression of how these two configurations would sound vs. a 10w6 in its "correct" .625 cf sealed enclosure?
-a
Either or really, the g2's are pretty decent subs. Both would sound good, but the output edge would go to the 2 vs. one driver. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My thoughts exactly
Pre fab boxes can make the best subs sound terrible. Plus its hard to get louder than 2 10's with one just because of the surface area difference. why dont you see if they can hook you up with a custom to spec box for your troubles and stick with the jl
TXslade
TXslade
san antonio
TXslade
