JL 1000/1 or 500/1
well you will be spending two times the ampunt of money and you will void your warranty on the sub. JL is not the best priced company out there and not the smartest but they know what there subs can and cant take and they are not rated to take a 1000/1 plus they bench closer to 1500 or so dont they? think a sub rated at 500wrms should be given three times it rated power? Im sure it will work and be loud I just dont think that sub will last long.
they dont put that much over..pry bout 1200....Be nice on the gains and u should be fine.
Also u can get a better budget amp for the amount of a 1000.1 but if u have the money it is a very good amp.
You could buy a Phoenix gold xenon 600.1 or 1200.1 and set the gains on them accordingly and they would work also, same technology as teh jl amps, 1-4 ohms running 600 watts rms
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
761
integra17
integra17
Edmonton, AB
Rezac
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
