JL 1000/1, JL 450/4, Planet Audio BB1400.1, Planet Audio BB4.150, Arc Audio KS1200.1
Tirefryr
PoonTang Addict!
JL Audio 1000/1, slightly used, but MINT
JL Audio 450/4, slightly used, but MINT
Planet Audio Big Bang 1400.1, used
Planet Audio Big Bang 4.150, Refurbished
Arc Audio KAR series KS1200.1, NIB, never used.
JL Audio 1000/1, slightly used, MINT condition
Rated Power: 1000 watts RMS at 1.5 ohm - 4 ohms (at 11V-14.5V)
THD at RMS Power:
S/N Ratio: >95dB below rated power
Frequency Response: 5Hz - 500 Hz
Damping Factor: >500 at 4 ohms /50Hz
Input Range switchable from 200mV-2V RMS
to 800mV-8V RMS
Dimensions: 19.7"L x 9.25"W x 2.36"H
JL Audio 450/4, slightly used, MINT condition
Channels 1 and 2:
Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
Channels 3 and 4:
Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
THD at Rated Power:
S/N Ratio*: >108.5 dB below rated power
Frequency Response: 5 Hz-30 KHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch./50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions: 13.4"L x 9.25"W x 2.36"H
Planet Audio BB1400.1, used, has some scratches, fully functional, one broken mouting foot
RMS Power Rating:
4 ohms: 625 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
1 ohm: 1400 watts x 1 chan.
MAX Power Rating:
1 ohm: 1900 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +18 dB bass boost)
Soft Start Turn-on
Mono channel operation
Strap two amps together for twice the power
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Input sensitivity:
Low level: 100mV-2V
High level: 2V-8V
Variable low-pass filter
Subsonic filter (15-40 Hz)
Phase Shift: 0-180º
Frequency response: 20-250 Hz
Dimensions: 17-3/4"L x 6-7/8"W x 2"H
Planet Audio BB4.150, refurbished, looks good with a couple scratches here and there.
RMS Power Rating:
4 ohms: 150 watts x 4 chan.
MAX Power Rating:
2 ohm: 300 watts x 4 chan.
Bridged, 4 ohms: 600 watts x 2 chan.
Variable Bass Boost (0 to +12 dB bass boost)
Soft Start Turn-on
4/3/2 channel operation
Low level inputs and outputs
Chrome-plated set-screw terminals
Input sensitivity:
Low level: 100mV-2V
High level: 2V-8V
Variable high-pass filter (50-250 Hz)
Variable low-pass filter (50-250 Hz)
Frequency response: 20-20,000 Hz
Arc Audio KAR series KS1200.1, BNIB, SPOTLESS
Output power (RMS) @ 1% THD 100HZ 14.4VDC
Power Output @ 4Ohm: 850 Watts @ 80A Eff. 75%
Power Output @ 2Ohm: 1200 Watts @ 124A Eff. 68%
Power Output @ 1Ohm: 1000 Watts @ 132A Eff. 53%
Total Harmonic Distortion: .01%
Frequency Range -3db: 15hz - 230Hz
Crossover Range: 30Hz - 230Hz
Subsonic Filter Range: 10Hz - 80Hz
Bass Boost: 0-15dB @ 30Hz - 125Hz
S/N Ratio (A wtg) ref 1 watt 4Ohm: > 70dB
Separation: NA
Damping Factor 25W out 4Ohmz 100Hz: > 1000
Input Sensitivity (RCA):
.30V - 6.5V @ 4Ohm
.25V - 5.3V @ 2Ohm
.15V - 3.7V @ 1Ohm
Input Impedance: 13K Ohms
JL Audio 1000/1 and 450/4----$625+shipping to the 48 continental. These are perfect together and I prefer to NOT separate them, however, money talks.
Planet Audio BB1400.1----$125 shipped to the 48 continental.
Planet Audio BB4.150----$125 shipped to the 48 continental.
Arc Audio KS1200.1---- $425 shipped to the 48 continental OBO.
All items will ship day after payment unless I can get them out before that. If paying via Paypal, you must cover the fees or send money as a gift.
More photos can be seen here, but I don't want to clutter the thread.
FOR SALE Photos by tirefryr | Photobucket
Tirefryr
PoonTang Addict!
Tirefryr
IN
ThatChevyGuy
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
