JL 1000.1 amp
I've checked and rechecked my grounds.. I even go to another forums where it's specifically all about the truck I own and I used the most common ground they mostly use..
So grounds aren't the issue I know that for sure...
However I do remember when installing this (Long *** time ago, when I didn't know shet) my dumbass friend actually touched the positive and ground together and created a spark... Right before I was going to ground it and hook up the positive to the amp...
Could the wiring be shorted out somehow and causing bad connections or ???
yes but not when its $1000 at the store. thats $1/watt
My point exactly..
but anyways so someone don't miss it...
it is internally regulated so you shouldnt be getting dimming
prob have a problem with overall electrical gett a dmm and see what its drawing when running
My point exactly..
just follow your wiring and see if something is wrong with it. also, head to autozone and have them check your alt and batt to make sure theyre good
I'm going to check all the wiring tommorow.. and my wiring is only 4 guage from batt to amp.. so I might just upgrade it to 0 gauge from Knu sometime soon..
Batt is brand new.. less than a month old and was tested before going in..
Alt is good.. my dads a mechanic at Chevy and he tested it last week..
Idk wtf is wrong..
Maybe new 0 gauge wiring from batt to amp will fix it??
Any other suggestions??
Yeahh I'll try the 0 guage in two weeks.. I'm saving for tires for my 23s right now..
I'll let you guys know if it helped or not..
by the way fuses are good.. I literally checked them all.. haha don't ask.. long tuesday night..
Can't really think of anything else myself but if you can let me know..
STR8BLaZiNTB
STR8BLaZiNTB
Orange County, Cali
rusty_armadillo
