Jensen DVD volume question
I have a Jensen VM9511TS and When I play DVDs I have to turn the volume up a lot higher to hear it. Then, when I switch back to radio the deck is BLASTING!!!!! Have any of you heard of this? Is there anything I can do?thanks
are you playing burned dvd's?
I have the VM9311TS and yes, the DVD volume is lower than the Tuner or Aux. Input. Unfortunately, after reading through the manual it doesn't look like Jensen has the Volume Equalization Compensation like some other units do. I just turn the volume up a bit more. If you are using an external amp, you can just crank up the gains a little more to give you a higher ceiling.
If it's too loud, you're too old!
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
Richard76
