JBL W12GTi MkII 12" Dual 6 ohm GTi Series Subwoofers and JBL GTO24001 Grand Touring 2
ElOsito
For less than 600 hundred , they say brand new still in the box , but not really sure , havent seen them. Well anyone have any feedbacks on these subs , heard great things about them, sound quality n all , or the amp?
But would that amplifier power them any good maybe actually pushing them to theyre limits or so? them being 6 ohms and the amp being stable at only 4 and 2 ohms
Subwoofer specs:
Sensitivity: 91 dB
RMS Power Range : 700 Watts
Peak Power Handling: 4000 Watts
Impedance: 6 Ohm
Low Frequency response: 18 Hz
High Frequency Response: 1000 Hz
Diameter: 12 Inch
Number of Voice Coils: Dual
Amp specs:
Max power output: 2400 watts x 1
1750 watts RMS x 1 @ 4 ohms
2400 watts RMS x 1 @ 2 ohms
MOSFET power supply
Wired remote bass level control included
LED power indicators
Tuned Bass EQ (0-12 dB bass boost)
Single channel operation
1 Set of preamp RCA outputs
Heavy duty aluminum alloy heatsink for maximum heat dissipation
RCA level inputs
Screw terminals
Variable high-pass filter (10-100 Hz, 24 dB/octave)
Variable low-pass filter (32-320 Hz, 24 dB/octave)
Frequency response: 20-330 Hz
Dimensions: 24-7/8"L x 10-3/8"W x 2"H
Good deal or nah?
The sub is a dual voice coil 6 ohm. Which is wireable either in 3 ohm or 12 ohm load depending how you wire it. Series or parallel. Consult a subwoofer wiring diagram. Also that particular sub is good for well over 700 rms watts but that amp you're looking at is pretty big. Although if you set the gains carefully (with a DMM) it would leave you room to expand. As far as that being a good deal. 600 seems a little high unless you're getting a warranty with them. If I were you I'd either get the equipment installed or do some research first as far as wiring subwoofers and setting the gains on an amplifier, etc. Your lack of knowledge is going to make things more difficult and you could end up damaging some very pricey equipment.
I have W15GTI's and brand new (manufactured refurbished) GTO2400's for you if interested. The amps are brand new from Harman and have full warranty. Let me know if interested I'll work a good deal for you
ElOsito
ElOsito
Los Angeles
stony22
