I have a JBL P180.2 (2 channel) amp that I'm pushing 2 jls with. The problem is, it puts out 360w rms bridged at 4 ohms, or 180w x2 rms 2 ohm stereo, but only 90w x2 at 4 ohms. Maybe it's common practice, but I'm still kind of a newbie, and I was thinking of trying the following:
-Tying the positive output terminal from each channel together, and tying the negative terminals from each channel together. It would basically be a stereo configuration, just with jumpers from positive to positive and negative to negative. This way, each channel would see a 2 ohm load. Each channel's output would be split between subs, but the full 180w x2 would be utilized (ie. each sub would get 90w from each channel). My question is, is it bad to push a sub with power from both channels without using the standard bridge configuration? I'd be running the amp to put out a mono signal, so it wouldn't be a different output on each channel. Would this configuration work properly?
407
407
