JBL HT trade for xbox360 or ps3
Stock pics from JBL, my sub is black though
General
Amplifier Power (RMS) 100 Watts
Driver 200mm (8") Pure-cellulose-fiber cone
Inputs Line Level (switchable to LFE) and Speaker Level with 5-way binding posts
Peak Dynamic Power 225 Watts
Low-Pass Frequency Variable from 50Hz - 150Hz
Frequency Response 35Hz - low-pass crossover setting
Dimensions (H x W x D) 413mm x 279mm x 349mm
Weight 13,6kg
CSB5
General
Frequency Response (–6dB) 60Hz – 30kHz
Maximum Recommended Amplifier Power 125 Watts
Power Handling (Continuous/Peak) 40 Watts/300 Watts
Nominal Impedance 8 Ohms
Sensitivity (2.83V/1m) 88dB
Crossover Frequencies 3.2kHz; 12dB/octave
Low-Frequency Transducers 5" (130mm) PolyPlas™, video-shielded
High-Frequency Transducer 3/4" (19mm) Titanium-laminate dome, video-shielded
Dimensions
(H x W x D) 14-5/16" x 6-1/8" x
4-9/16"
(338mm x 155mm x 116mm)
Weight 4.5 lb (2kg)
Mine are sill in the boxes and packed away in the garage somewhere.
dacheatham
dacheatham
Russellville, Arkansas
dacheatham
