I was going to use these as a cheap alternative to my ADS or just keep them but I cant...
These were sold to me as new but tested on a bench...never mounted in a vehicle as the system never happened. they both come with boxes and manuals.
GTO752.....ASKING $ PRICE DROP NOW $150 shipped for the pair...........................!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.sonicelectronix.com/item_12246_JBL+GTO752.html
PRODUCT DESCRIPTION:
JBL GTO752
# Grand Touring Series 2-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 75 watts x 2 chan.(actually seen where this amp does 92x2 ..so its a little underated- you get more than advertised power)
* 2 ohms: 110 watts x 2 chan.
# Max power output: 220 watts x 2 chan.
# LED power and protection indicators
# Tuned Bass EQ (0-12 dB bass boost)
# Preamp RCA outputs
# Cast-aluminum heatsink
# Variable high-pass filter (32-320 Hz, 12 dB/octave)
# Variable low-pass filter (32-320 Hz, 12 dB/octave)
# CEA-2006 compliant amplifier
# Frequency response: 10-100000 Hz
# Dimensions: 12-1/4"L x 10-3/8"W x 2-1/8"H
# 8-gauge power and ground wiring is required for installation.
GTO504...asking $see above
http://www.sonicelectronix.com/item_12243_JBL+GTO504.html
# Grand Touring Series 4-Channel Class AB Car Amplifier
# RMS Power Rating:
* 4 ohms: 55 watts x 4 chan.
* 2 ohms: 70 watts x 4 chan.
# Max power output: 140 watts x 4 chan.
# Tuned Bass EQ (0-6 dB bass boost)
# Dimensions: 13-3/16"L x 10-3/8"W x 2-1/8"H
# 8-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
JBL GTO752
# RMS Power Rating:
# RMS Power Rating:
