Jbl gto2400-z
  • 1
nate56
colorado
1. Product:
FACTORY-REMANUFACTURED JBL GTO24001-Z
2. Specs:
Output power (RMS, ≤1% THD + N; 2 ohms)2400W x 1
Output power (RMS, ≤1% THD + N; 4 ohms)1750W x 1
THD+N0.5% (rated power @ 4 ohms)
Maximum power2400 watts
CrossoverBuilt-in variable electronic crossover
Frequency Response20Hz – 320Hz (–3dB)
Signal-to-noise (@ 1W)65dBA (reference 1W into 4 ohms), 97dBA (reference rated power into 4 ohms)
InputsRCA low-level preamp inputs
OutputsRCA low-level preamp outputs
Back-litJBL logo badge & dual LED light bars
Bass boost (+6dB @ 50Hz)Dynamic bass Optimization (DBO) circuit
Dimensions (L x W x H)630mm x 263mm x 53mm (24-13/16" x 10-3/8" x 2-1/8")
3. Description/Condition:
looks 8-9/10 minor scatches
working 10/10 still has a 1 yr warranty
4. What you are looking for: :
low budget 15's about 500-800 RMS
5. Pictures of your item for trade:
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
nate56
nate56
colorado
nate56
    May 18, 2024
    May 18, 2024
