Sold JBL BPx2200.1
Speakerman
Don't touch my willy
Hello everybody, I have a JBL BPx2200.1 up for sale. I’ve had it for a while and it’s been sitting in my closet for a good while because I got a different truck.
The amp is in perfect condition. It comes with all the papers, warranty, packing, birth sheet, and bass knob.
Here are the specs for it. They are quite a bit under rated. The birth sheet says 2400 @ 4 Ohm I believe.
2200 Watt Parallel/Bridge Subwoofer Amplifier
2200 Watt Parallel/Bridge Subwoofer Amplifier with Dynamic Bass Optimization Circuit.
• Unlike conventional mono subwoofer amplifiers that only deliver their maximum power into a single impedance, the BPX1100.1 and BPX2200.1 are two-channel amplifiers that can be bridged to deliver double the voltage of a single channel into impedances between 2 and 4 ohms. The two channels can also be connected in parallel - that’s right, parallel - to provide double the current of single channel into impedance below 2 ohms. This feature is patented and unprecedented in car audio amplification. Thanks Crown!
• Slope-selectable variable electronic crossovers - Both the BPX1100.1 and BPX2200.1 is equipped with a variable electronic crossover capable of setting the slope rate at 12dB or 24dB per octave. The crossover adjustment range is 32Hz - 320Hz.
• Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure’s tuning frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized.
• High Effective Damping Factor - Both the BPX1100.1 and BPX2200.1 have a high Effective Damping Factor. The result is better subwoofer control and lower distortion.
• Both the BPX1100.1 and BPX2200.1 come equipped with a remote bass level control allowing you to optimize bass output for specific music or preferences from the driver's position.
• Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitters needed.
My price is going to be 700 shipped if paid with my check, or 725 shipped if paid with Paypal. I can’t accept any trades.
I really should pick this up to run on one of my single 4 ohm custom subs I just picked up .. I'd like to see if I could beat your excursion vids //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Speakerman
Speakerman
College Station, Texas
Speakerman
