JBL BP-1200.1 Mono Sub Amp - works great- true 1200 watts!
ampjunkielikeme
Item(s) for Sale: SOLD! JBL BP-1200.1
Output Power at 12.5V:
1 x 600W @ 4 ohms
1 x 1200W @ 2 ohms
this is a great working JBL 1200.1 powervalve mono amplifier.. it has been fully tested . its ready to be unleashed on your subs.. it puts out some serious power at 2 ohm. and it is stable at 1ohm ( as long as you have a good electrical)...
the amp looks very good for its age... it has a few scratches and scuffs , but it still looks great......
this amp is pretty much half of a orion 2500d... yep, that is what i said.
sold!
jbl spec:
JBL PowerValve series amplifiers deliver pure, clean power with the soul of JBL pro gear. The PowerValve P-1200.1 features a high-efficiency Switching power supply that draws far less current from your vehicles electrical system. PowerValve amplifiers are also 2-ohm optimized, and can run a 1-ohm load with ease. The "Direct Connect" terminal block power connectors allow for either 8 gauge or 4 gauge power wire, and the die-cast aluminum heat sink uses the entire amp footprint for efficient cooling. Plus, the buttoned black chassis with embossed JBL logo has an awesome, menacing look. With selectable 2- or 4-channel inputs, PowerValve amplifiers can be hooked-up for non-fading bass. Drive your subwoofers with JBL PowerValve power and you'll know why JBL is the official brand of live music.
im running a 50hz tone through the amp powered up and its putting out ac voltage
side view
side view
pic of the board( powered up)
ampjunkielikeme
ampjunkielikeme
nash, tn
ampjunkielikeme
