JBL 1200 or Memphis 1000
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 1K
  • 2
U
Unregistered
Guest
Which amp would do 2 kicker L7'2 4 ohm(but wired at 2 ohms) ? If not those amps, give me a suggestion, I really need an amp that can handle these subs cause i dont wanna fry the amp.
i would go with the jbl 1200.1 if not then go with the mtx 81000.d those are to good amps, i have a mtx 81000 pushing a audiobahn 15 pressure sub thats 2000 watts rms and it pounds hard....the jbl is also just as good also u can wire ur subs to the mtx at 2 ohms and it will handle them
My personal choice up until recently would have been the ST1000D. BUT...the thing with Kickers is that the harder you drive them, the better they sound. From a good, clean amp they can take almost twice their power all day long. Id go for MEMHIS's new class D amp - the MEMPHIS MOJO - stoopid name I know, but BIG power - 1x1200RMS@1ohm and 2400@2ohm.
Only down size I suppose is the price. The mEmPhIs is probbaly more eXpensive. JBL have always made good products at a good price but when you come up against somebody like MeMpHiS, its a difficult decision.
Memphis Mojo, all the way. My $0.02.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
982
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
Guest
jtmoney
    May 12, 2024
Brendon Jenness
    May 11, 2024
