Jbl 1200.1
LHSroller
Welch
Now, lets say that I get a JBL 1200.1 and run it at 4 ohms to create 600W RMS. Would this pull more or less amperage than running a JBL 600.1 at 1 or 2 ohms creating 600W RMS? Or would each pull the same cuz it is creating the same amount of watts....but I dont know...please help.
When you wire an amp into 2 ohms, you're not TECHNICALLY getting more watts, you're just lowering the resistence, so it increases the current and more power is given to the speaker. The problem with lowering the resistence is THD (distortion). The resistence on an amp works much like a water filter, the thicker the filter (more ohms, higher resistence), the more pure the water coming out will be, but the output will be significantly less (itll take more time for the water to come through) If the filter is thinner (lower resistence), it will be faster, but it might not get all the impurities out. If you look at amp specs, it will give you a THD level at 4 ohms and at 2 ohms...the THD at 4 ohms is usually MUCH lower than at 2 ohms, so to answer your question, the amount of power would be the same, but if you got the 1200.1 and wired it at 4 ohms, you'd get a bit cleaner signal than if you ran the 600.1 at 2 ohms, but with the price difference, most would go with the 600.1 because it isn't going to be too noticeable...
Keep it loud!
JELLYDIME
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
879
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
5K
LHSroller
LHSroller
Welch
mykeys
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
